Re: H Oil Leak H Steering Wobble
Posted by The Red on July 11, 2000 at 07:11:21 from (206.246.187.2):
In Reply to: H Oil Leak H Steering Wobble posted by Brent on July 10, 2000 at 18:44:59:
If the leak is not coming from the valve cover and it is leaking on the distributor side, it is probably leaking from the rocker arm inspection plate. That gasket gives out about as often as the valve cover gasket. If that is the source, I recommend you pull the oil filter can and cover up that base, then you will have plenty of room to remove the cover. If the rocker arm chamber is really gunked up, this is a good time to remove as much of that old oil sludge that you can.
Post A Followup
: Re: Re: H Oil Leak H Steering Wobble
