Posted by Roger46 on January 23, 2011 at 10:44:21 from (72.100.156.53):
In Reply to: b oil gear posted by ken is #3 in md on January 22, 2011 at 15:00:42:
Ken, I assume this is on a Farmall A or B tractor. The primary purpose of that oil slinger gear is to lub the upper gears when doing belt or PTO work with the tractor when it is not being driven. It is common for that gear to have lost it's teeth. That oil slinger gear was bad on both my A and B when I did a restoration. My theory is that this aluminum gear is in the bottom of the transmission and in the winter when water freezes in the bottom of the transmission this gear freezes into the transmission. When the engine is started and the clutch let out, the upper shaft starts spinning and it tries to turn that gear (which is frozen in). It strips out the teeth and then once a section of teeth is stripped out eventually they all strip out as the gear skips through the missing teeth section. Anyone else have any other theories? Roger
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
