Re: F-20 block
Posted by rusticredacres on January 23, 2011 at 13:29:20 from (209.43.81.150):
In Reply to: F-20 block posted by preacher777inky on January 21, 2011 at 05:52:22:
I do have several different ones if you still need one call me at 317-512-0493 or email me and I will fix you up. Dwayne / Rustic Red Acres Tractor Parts
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
