Posted by D Slater on January 23, 2011 at 14:36:26 from (184.15.40.132):
In Reply to: H head cast# posted by lo HP IH owner on January 23, 2011 at 11:46:20:
That is a distillate head. If it just has a D following the number, you have a early H if the head is original to it. If it is a early H the frame rails you wanted to change in the other post may use the rubber mounts between the engine and the frame rails. IH went to solid mounts between the frame rails and engine because of frame rails warping in around early 1942. If you have the rubber mounts I would support part of the weight when changing the rails. I think its a good practice on the solid type. Even if its not a have to thing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
