Re: H head cast#
Posted by Jay Snyder on January 23, 2011 at 17:48:14 from (71.87.118.248):
In Reply to: H head cast# posted by lo HP IH owner on January 23, 2011 at 11:46:20:
Yes you have a distiliate head. Same as mine and yes the engines are rubber mounted. I did put a jack under my hydraulic pump but thats all when I changed mine and really the only reason it was under there was I had to split the tractor to get a bolt I dropped in the starter hole out. Make sure if you change it to new rails you get new style engine mounts for it. Lots of old war model tractors around with busted frames. Mine is a 1942 but its a early 1942. Any more questions feel free to ask.
Good Luck
Jason
