Posted by Owen Aaland on January 23, 2011 at 19:00:12 from (65.165.246.79):
In Reply to: Farmall H frame rails posted by Wardner on January 23, 2011 at 07:50:29:
If you have an early model with the rubber front mounts it's probably a good idea to support the center behind the engine. The later ones with the cast iron spacer blocks you can most likely get by without any additional support.
You will need to make sure you get the correct replacement rails. On the early one the front mount holes are closer together than the later ones.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
