Re: Rear weights
Posted by John A. on January 23, 2011 at 20:20:10 from (76.1.122.180):
In Reply to: Rear weights posted by Farmall_H_puller on January 23, 2011 at 18:31:54:
Farmall H, Yes depending on how much wt you want to carry. Unless you have CaCl & H20 then I would say you need equal # of 2 piece wt for the insides, leaving the 1 piece for the outsides.
For every pair you add to rear corner that is about 300 lbs. You can use the 4 holes in the cast wheel, and the wts and go as wide as 5 & 5 ins and outs fairly easly.
I have a 966 also Mine has the huge one piece aftermarket cast wts 950 + - lbs. No fluid in tires either, cast only. I have a loader on mine so I am a huge believer in cast wt.
So the 2 piece/1piece method as I described above is how I would approach this. 1 single wt is not much help in the grand scheme of things. Hope this helps.
Later,
John A.
