Re: Cub Gas Tank Restoration
Posted by Andrew Z on January 24, 2011 at 09:54:51 from (64.252.115.246):
In Reply to: Cub Gas Tank Restoration posted by The Rock on January 24, 2011 at 09:47:27:
If you have a really poor tank have it cleaned at at a radiator shop. If it is not too too bad then clean with acetone or other acid. Unless the tank is prepared 100% the tank sealer can loosen in years to come, making a real mess. If you can get by without it then do so. If not take it to a pro. You can search the archives youll find 100's of tank cleaning posts.
Andrew
