Re: H Lower Bolster Orientation
Posted by wayne in mn on January 24, 2011 at 09:56:32 from (66.228.242.147):
In Reply to: H Lower Bolster Orientation posted by Doug Kieta on January 24, 2011 at 09:05:53:
Yes, it is reversed from its correct position. There should be one "stop" bolt (taller head) to prevent the wheels from making a complete 360° rotation. The bolt should be in the front left hole (if memory is correct). Look under the casting to determine proper location.
