Re: H Lower Bolster Orientation
Posted by rustcollector on January 24, 2011 at 16:55:44 from (67.142.161.30):
In Reply to: H Lower Bolster Orientation posted by Doug Kieta on January 24, 2011 at 09:05:53:
If the bolster is backwards, the stop bolt can be removed by finding the hole in the housing above, pushing the bolt out, spin the wheels around with the steering wheel and swapping with a non stop bolt in the proper position. You'll have to remove the non stop bolt and put it where the stop bolt came out before replacing the stop bolt. This can be done without jacking up the tractor or opening the top to the bolster.
