Re: L W; how is your 240 project goin'
Posted by farmallhal on January 24, 2011 at 16:56:48 from (76.2.177.91):
In Reply to: Re: L W; how is your 240 project goin' posted by redFarmallboy on January 24, 2011 at 12:30:45:
My 240 is a narrow front row crop Farmall model and it's on the left hand side of the clutch housing below the voltage regulator and behind the air cleaner unit. It's easily seen and if not on your tractor it's probably missing but you should be able to see the four rivet holes where is was secured. If you have an International 240U model I don't know where it would be located if not in the same location. Hope this helps, Hal.
