Posted by Bob M on January 24, 2011 at 18:15:07 from (67.240.171.41):
In Reply to: exploding battery posted by realolman on January 24, 2011 at 16:52:15:
I had a nearly new battery explode on my Minnie Mo U a couple years ago.
Temperature had been in the low 20's overnight; the tractor had been warming up unattended about 5 minutes when the battery let go. Fortunately no one was nearby when it blew (the battery sat exposed beneath the gas tank)
Problem turned out to be a bad voltage regulator causing severe overcharging the battery. The source of the spark to set it off however I could never determine.
I now have the battery inside a vented marine-style plastic battery box. Figure should it blow again the box will contain the acid and flying bits of battery.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
