Re: 560 rod bearings
Posted by pete 23 on January 25, 2011 at 16:11:36 from (173.87.15.134):
In Reply to: 560 rod bearings posted by cory s on January 25, 2011 at 13:11:02:
You could have them custom made as you probably know. Far as undersizes go, IH always ground their exchange shafts to .030 under on the gasoline engines although they offered the .010 and .020 bearings also. Some repair shops won't use any ground shafts, others use many different sizes. It is what you are comfortable with and have had experience with. And of course there are some shafts you just don't grind at all depending on material and hardening process they were mfg to.
