Posted by Armand Tatro on January 25, 2011 at 20:33:32 from (71.239.9.235):
In Reply to: locked up H posted by jbuckshot on January 25, 2011 at 18:28:27:
My understanding is that when you push clutch peddle with foot that disengages clutch. Taking foot off clutch peddle engages clutch. That being said you disengage clutch to start tractor(no load on engine). Engine runs with no load. Now when you engage clutch with trans in neutral does engine lug down and die? If yes trans. is locked in 2 gears. Shifting lever is worn. Take shifting tower off, look at shifting rails and put all rails in neutral with big screwdriver. If engine lugs and dies after you put trans in a gear than you could have a piece of a bearing or other debrei(sp?) stuck in 2 gears(BTDT). Is also possible frozen water intrans. Have you removed drain plug to see if oil runs out. If oil drains out no frozen water. in trans. Post back what you find or if you have more questions. Hopes this helps. Armand
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
