Posted by D Slater on January 26, 2011 at 05:26:17 from (184.15.23.120):
In Reply to: locked up H posted by jbuckshot on January 25, 2011 at 18:28:27:
If the tractor will roll okay when shifter is out of gear and clutch engaged, its not in two gears. Something is keeping the transmission input shaft, lower transmission shaft or belley pump from turning. If you don't find any ice, a roller from the main shaft pilot bearing can come out and wedge between the constant mesh gears. With the clutch pedal blocked down, trans out of gear put the pto in gear and see if it can be turned backwards or back and forth to dislodge anything stuck in the gears. Would remove the front trans drain plug to make sure no ice under the constant mesh gear first. Ice most times blocks the bull gears also if its there though, then tractor wouldn't roll. Maybe drop the inspection cover under the hydraulic pump drive shaft and make sure pump shaft turns also. If easy stuff fails remove the belt pulley gear box or cover and look for the problem. This is just guess work without inspecting what you have.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
