Re: Char-Lynn P.S. system on Ebay
Posted by D Slater on January 26, 2011 at 13:46:25 from (184.15.23.120):
In Reply to: Char-Lynn P.S. system on Ebay posted by Yooper Farmall on January 26, 2011 at 13:01:21:
Pump bracket won't fit a H. crankshaft pulley won't fit. Torque generator mounting bracket is not correct for a H. Half of the high priced steering shaft coupling is missing. Don't see the fan spacers needed to make a complete M set up also.
That pump can be mounted high on a H engine and the reservoir mounted back where the starting gas tank would go if K. or D. That way no hole in the hood is needed. Regular charr lynn pump kits for a H,SH mounted the resrvoir direct to pump. Top of the reservoir ended above hood line.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
