May depend on the fire crater pistons you have. Fellow brought me a 450 LP that had a M gas head on it. He wanted it changed back to the 450 LP head. When I removed the head I found fire craters. Was afraid they wouldn't clear the head. After checking there was no problem with clearing on it. But they were standard elevation fire craters for a 400, 450. They made 4.125 pistons for the SM heads that were different. Also different elevations were made.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
