Re: W 400 Decales
Posted by Wardner on January 27, 2011 at 12:42:46 from (209.86.226.40):
In Reply to: W 400 Decales posted by Rod in MN on January 27, 2011 at 11:28:58:
There are ten small decals on a W-400.
There are also the same ten small decals on a F-400.
The 450s have two more decals which are the left and right white hood panels.
air cleaner instruction
brake warning
caution 6 (12 volt for 450) volt electrical system
drawbar warning
gear shift
lighting switch
oil filter instruction
power take-off warning
pressure cooling warning
IPTO seasonal disconnect warning
Buy the F-400 set and you will be OK. After market sets may have both the 6 and 12 volt decals.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
