Re: C charging problem
Posted by teddy52food on January 27, 2011 at 18:35:00 from (68.169.216.43):
In Reply to: Re: C charging problem posted by CNKS on January 27, 2011 at 18:28:58:
If his battery is running down to where he has to put a charger on, the generator should be charging 10 to 15 amps. Get a voltmeter on the battery & you should have 7.4 volts. If it is lower , the regulator needs to be set up accordingly.
