Re: Battery cable size
Posted by farmallhal on January 27, 2011 at 19:25:56 from (76.2.177.91):
In Reply to: Battery cable size posted by Bob Day on January 27, 2011 at 04:27:55:
Size 00 with soldered lugs and run the ground to a starter to frame bolt and that is about the best you can do. I also use those external teeth washers between the starter frame and the cable for a good electrical connection as they bit into both metals. As others have said if you are in a very cold area you may find a 12 volt conversion better suited with less issues. What I described works find on the H and smaller tractors on 6 volt systems. Good luck, Hal.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
