The F-504 and 606 appear to me to be the same tractor with different engines and misc like wheels. The 606 uses the 236 cubic inch six cylinder. There is alot of empty space between the F-504 engine and the radiator.
That 236 engine will swap with the six cylinder 263, 282, 301 engines. May have to change the front gear cover and/or water pump depending on which tractor or combine the replacement engine comes out of. Combine engine may not be drilled for clutch pilot shaft. Probably have to use 504 flywheel which may need to be re-drilled for the six cylinder crankshaft.
Seeing as no one else on this forum has offered advice on this subject, call Mike Bunck at Steel Wheel Ranch and get his opinion on what can be done.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
