Re: Tire fluid options
Posted by mkirsch on January 28, 2011 at 13:51:52 from (64.80.108.56):
In Reply to: Tire fluid options posted by Yooper Farmall on January 28, 2011 at 11:33:47:
On a 12.4x38, three sets of iron weights is about the same as fluid. You won't have quite the same effective traction, but possibly close enough for your purposes.
CaCl solution is only corrosive if a leak is not immediately identified and fixed. New tubes in new tires on new rims shouldn't leak.
Consider the rims are probably ORIGINAL on that tractor. It's roughly 65 years old. It took 65 years for the calcium to eat out the first set of rims... How long will the second set last? Probably longer than you'll need 'em.
