Re: Tire fluid options
Posted by glennster on January 28, 2011 at 14:30:29 from (76.223.251.130):
In Reply to: Re: Tire fluid options posted by Zachary Hoyt on January 28, 2011 at 14:09:33:
zach, mkirsch is correct about the 3 sets of weights. they weigh about 140 lbs per weight, so 3 weights would give you about 420lbs, 3 pairs 860 between 2 rear tires. all 3 of my loader tractors run fluid and weights. my cub, b, 240u and w-9 also are loaded. its not a real issue to pump the fluid out yourself, a 12v sprayer pump works fine. you need the fill adapter for the valve stem. i have an old 100 gallon poly chemical tank that i use for mixing/storing the liquid chloride.
