Re: loose pitman connection on sicle bar of sicle mower
Posted by Redfan on July 12, 2000 at 03:56:26 from (203.87.53.9):
In Reply to: loose pitman connection on sicle bar of sicle mower posted by Rod Hergott on July 11, 2000 at 20:26:50:
If it is the spring loaded, over centre type clamp, there's only really two options. The ball on the the knife head has worn and will need building up. Otherwise the spring steel arm has lost it's temper or is cracked, and you'll need a new pitman end. Regards, Redfan.
Post A Followup
: Re: Re: loose pitman connection on sicle bar of sicle mower
