Re: farmall M gas tank mounting
Posted by 43warhorse on January 29, 2011 at 08:01:04 from (174.252.38.156):
In Reply to: farmall M gas tank mounting posted by mainamana on January 29, 2011 at 07:36:18:
The isolaters, rubber bushings or springs are used to keep the tank mounting points from cracking and leaking. You figure gasoline at almost 8lbs a gallon is a lot of weight moving in the tank. With out the rubber mounts it would beat itself apart and leak.
