An isolator (Synthetic rubber/cloth) pad buffers the tank at both ends from direct contact with the supports. Studs through fairly large holes are the fasteners. there is a washer-spring-washer-nut combination on each stud to compress the spring. This allows the tank to expand and contract at a different rate than the tractor under it without being stressed. It also allows easy alignment and assembly. There is also a strip of buffer between the tank and the hood for the same reason. The parts diagrams on line at caseih.com show the assembly clearly. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
