Posted by Janicholson on January 29, 2011 at 19:42:30 from (67.72.98.57):
In Reply to: M engine posted by poco on January 29, 2011 at 18:36:08:
247.7 was the gasoline engine displacement from the factory. The engine has likely been rebuilt one or more times, so there could have been changes, the most common is 264 Cubes if the Thin sleeves were used to match a Super M. But larger displacements can be provided with running the piston in the cast bore, and boring the cast bore larger and even bigger pistons. Stroking is also possible, but not likely unless someone was carried away. Displacement could be taken with a fluid in the cylinder and measured for volume, but it depends on how earnest you are in determining the displacement. Jim
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
