Re: Battery theory....
Posted by teddy52food on January 30, 2011 at 09:44:33 from (68.169.216.43):
In Reply to: Battery theory.... posted by Dellbertt on January 30, 2011 at 05:27:29:
I have taken a 12 volt with a bad cell and cut it in two & used it as a 6. Cut the case & then use a sharp small chisel to remove the plates from the lug coming out of the cell. I drilled a hole in the lug to bolt a cable on. I put plastic caps on the good cells to keep the acid in & drain the rest before cutting. I had one that lasted longer as a 6 than at 12.
