Re: Farmall Rear Combination Light
Posted by K-Mo on January 30, 2011 at 11:49:49 from (67.55.164.37):
In Reply to: Farmall Rear Combination Light posted by MSFARMALL on January 30, 2011 at 10:58:25:
Does it flash at a steady rate? If so, it could have a flashing bulb such as the No. 257 (12 volt). This bulb will stay on for couple of seconds to warm up and then flash at a steady rate. The No. 257 bulb is sometimes used as a flashing warning light such as low oil pressure.
If the flash is not steady and flashes when you move the light, it's probably a loose connection or bad ground.
K-Mo
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
