Re: Farmall Rear Combination Light
Posted by K-Mo on January 30, 2011 at 11:51:42 from (67.55.164.37):
In Reply to: Farmall Rear Combination Light posted by MSFARMALL on January 30, 2011 at 10:58:25:
Does it flash at a steady rate? If so, it could have a flashing bulb such as the No. 257 (12 volt). This bulb will stay on for couple of seconds to warm up and then flash at a steady rate. The No. 257 bulb is sometimes used as a flashing low oil pressure warning light.
If the flash is not steady and flashes when you move the light, it's probably a loose connection or bad ground.
K-Mo
