Posted by Bob Rottinger on January 30, 2011 at 14:23:55 from (71.169.43.220):
I rebuilt the govenor asembly for a Farmall "A" by rebushing the speed change lever shaft and replaced the thrust bearing and the govenor shaft spring with the correct part. The governoer weights and pins were fine and needed no attention. The carburator throttle works fine. I readjusted everything as per the service manual. My problem is that when I try to increase the speed the speed control lever needs to pushed past the end of travel and the there is only a slightly higer increase in RPM. It sounds as if the govenor spring is not the right tension. How Can I test this if at all? Is it possible to get a different tension spring? I need suggestions. Thanks,
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It
... [Read Article]
Latest Ad:
[More Ads]
