Re: Int. 300
Posted by mike paulson on January 31, 2011 at 02:21:03 from (98.15.178.36):
In Reply to: Re: Int. 300 posted by Andrew Z on January 30, 2011 at 20:23:59:
yea, o-ring sounds like a fairytale. pull the head and have a look. if you ever removed a head on a modern automobile you will see they are pretty simple to remove. bring the head to a machine shop and have them check it for you. look down into the pistons and engine block and do your best to look for cracks. replace the head gasket and head, drain oil and coolant and replace and you should be good to go..
