Re: Are 766 Farmall and a New Holland Super 717 a good ch...
Posted by mkirsch on January 31, 2011 at 05:32:36 from (64.80.108.56):
In Reply to: Are 766 Farmall and a New Holland Super 717 a good choice? posted by NNY FARMER on January 30, 2011 at 16:34:19:
IH quit "tailoring" implements for specific tractors a long time before the 766. They made them more generic so they could be used with any brand of tractor of a certain HP range. Market share, any way they can.
A 766 will easily pull a 4-bottom plow in most any conditions. It'll do 5 bottoms in good ground. It'll pull a 16' drag or disk.
It should handle a 717 chopper in 2 rows of corn no problem, unless it's muddy or you've got hilly ground, and you like to fill your wagons.
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
