Re: Gasket Material
Posted by rumplestiltskin on January 31, 2011 at 10:38:06 from (192.88.212.68):
In Reply to: Re: Gasket Material posted by Nebraska Cowman on January 31, 2011 at 05:57:20:
Same here -- I've been using cereal boxes and paper juice cartons for years and never had a problem.
Mark W. in MI
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
