As crusty as that Alternator is, I would allow it to be melted down for the copper and aluminum. I believe there are several answers to the question: I would use a regular 10SI delco. Hook the #2 spade connector to the big terminal with a short wire and ring terminal. Hook the #1 spade terminal to the ignition switch through a diode (3 amp 50 volt PIV) with the stripe on the diode toward the alternator. (prevents the tractor from running after the key is shut off) A 15 ohm resistor will also work, as will a filiment style marker lamp bulb. Each of these are simple to wire in. The main terminal (big) goes to the amp meter on the side where the ignition and lights are hooked up. Most one wire systems are "always on" thus there is always a draw on the battery, even when it is not running. The factory (GM) saw fit to wire it as above, So Do I. The coil shown probably needs a resistor to drop its input voltage. It looks like a mid 1960s GM coil that did use a resistor omn the fire wall. It is correctly wired as to polarity. A 12volt no external resistor required coil can be used with no resistor. A 6volt coil can be used with a resistor. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
