Re: Weird Electrical/Lighting Issues
Posted by Janicholson on February 01, 2011 at 10:09:32 from (199.17.6.165):
In Reply to: Weird Electrical/Lighting Issues posted by AL Farmall Boy on February 01, 2011 at 09:20:17:
Two solutions Remove the light post and clean/sand the surfaces it is bolted to or screwed into. Then clear coat the joint after reassembly.
OR
Run a ground wire parallel to the hot light wire and solder it to the reflector. Attach the other end to the tractor on a clean shiny bolt and clear coat it to prevent corrosion. Jim
