That alternator is an original delco-tron external mechanical regulaltor type. A 12 SI is near identical to a 10SI. It looks like some one has adapted a regulator right at the field terminals. Interesting. At any rate, I would follow advice of previous posters on alt. Far as coil, if you don't have an ohm meter, I am sure your friend who is checking alt has one, primary on a six volt coil will be less than 2 ohms and a l2 volt will be about 3 or 4 ohms. And no , it will not have any effect on the charging system, only ignition like short life of points if too much current flow or weak spark if not enough current flow through coil due to too much resistance.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
