Re: Loader on an M ?
Posted by pete 23 on February 01, 2011 at 11:24:15 from (173.87.15.134):
In Reply to: Re: Loader on an M ? posted by pete 23 on February 01, 2011 at 10:29:05:
It gets complicated trying to figure out these things. Lifting capacity is going to depend on pressure of fluid, size of cyl and leverage at lift points. No way I can figure this for you. New loaders normally give you a lot of these specs with gpm and psi needed for pounds of lift. Can't help you much more than that. Extra capacity tanks don't usually work well on the belly pumps. They shoot oil all over unless you plumb them in such a way to return the oil to bottom of reservoir. I would try it without.
