Re: Loader on an M ?
Posted by Armand Tatro on February 01, 2011 at 11:34:11 from (71.239.9.235):
In Reply to: Loader on an M ? posted by Harley dK on February 01, 2011 at 08:58:07:
First of all you do not want a PTO pump on that tractor because when you push in clutch pump will stop same as if you were using the belly pump. You want a crank shaft driven pump. Do you have power sterring on that tractor? I have replace the PS pump with a belt-driven pump from a combine that had a 3/8in. pressure outlet to hook to the PS and a 1/2in. pressure to run the rest of your hyd. system. We have a 1941 M that is set up this way with 2 3spool hyd. valve and sometimes we have all 6 valves in use. I will be happy to answer any questiong. Armand
