Re: 966 brakes losing prime and pushing pedal back in your f
Posted by Owen Aaland on February 01, 2011 at 17:00:02 from (65.165.246.235):
In Reply to: 966 brakes losing prime and pushing pedal back in your face? posted by curt in ky on February 01, 2011 at 13:42:32:
You need to bleed the air out of the brakes. There is a bleed screw on the top of each brake piston housing. With the engine running, hold the pedal down for the side you are bleeding and open the screw. Let it bleed out until there are no more bubbles coming out. Repeat the procedure for the other side.
