Re: Battery hookup 966 Negative on one to positive on other?
Posted by Owen Aaland on February 01, 2011 at 17:06:41 from (65.165.246.235):
In Reply to: Battery hookup 966 Negative on one to positive on other? posted by curt in ky on February 01, 2011 at 16:41:20:
That is correct unless someone has replaced the batteries with a pair of 12 volt batteries instead of the 6 volts type it came with.
Your tractor is connected in series. The two six volt batteries are connected to add the voltages together to get twelve volts. Your truck has two twelve volt batteries connected in parallel. That method add the amperage available but does not increase the voltage.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
