Re: starting and staying trouble
Posted by Bill in NJ on February 02, 2011 at 05:13:39 from (4.248.91.163):
In Reply to: starting and staying trouble posted by cary brief on February 01, 2011 at 22:07:21:
Sure has indications of a fuel flow problem. Ice?? I would remove the fuel line where it goes into the carb and see if you have good fuel flow. If you have good fuel flow to the carb there could be something going on in the carb, ice, float level?? If fuel flow is not good work your way back to the tank and find the block. Only ignition thing I can think of is condenser. Sometimes they will cause a problem like that. As far as the hard starting goes, are your battery cables big enough? If they are heating up during cranking they are not big enough.
