Re: starting and staying trouble
Posted by mkirsch on February 02, 2011 at 05:22:41 from (64.80.108.56):
In Reply to: starting and staying trouble posted by cary brief on February 01, 2011 at 22:07:21:
Allan hit the nail on the head. There's nothing wrong with your tractor.
You need to learn how to use the choke to keep it running until the engine warms up.
When it starts to die, pull the choke lever quickly, then push it back ahead. It only takes a blip at a time, but it might take several blips before the engine stabilizes and runs smoothly.
Every tractor is a little different, but they all need some choke when it's cold.
If the tractor starts right up, there is NOTHING wrong with your ignition. Leave it alone. You'll create more problems than you'll fix.
Try the choke idea before you do anything else.
