Re: Pertronex ignition - should I spend the money?
Posted by Hayfarmer on February 02, 2011 at 07:09:32 from (71.80.197.209):
In Reply to: Pertronex ignition - should I spend the money? posted by Leon Torkelson on February 02, 2011 at 06:43:58:
I have the pertronex electronic ignition on 2 tractors, a SMTA and an older JD430 and it is great. You never have to worry about keeping points adjusted. With the cost of a set of points and condenser at around 20 bucks it pays for itself. It isn't any different though than having a properly set ignition. I don't think it is the only solution to your problem though by replacing everything it will probably solve the problem. You may have a new condenser but I would try the another one, or may be the coil although usually it takes longer for them to heat up than 30 seconds. Are you sure it isn't fuel? I would thing about ice in a fuel line that partially plugs it. when it sits enough fuel goes through to start, but only to run a short time.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
