Re: Should my 12v SC have a ballast resistor?
Posted by Janicholson on February 02, 2011 at 07:32:59 from (199.17.6.165):
In Reply to: Re: Should my 12v SC have a ballast resistor? posted by Faster346 on February 01, 2011 at 18:38:37:
If it does get warm, the coil is already damaged. I would suggest that even if it does continue to run with a ballast resistor, the coil is now suspect as it has heated to failure several times. Jim
