Re: rear steel wheels - will M axel mounts work on H
Posted by sflem849 on February 02, 2011 at 19:14:46 from (69.197.84.192):
In Reply to: rear steel wheels - will M axel mounts work on H posted by ihtrucker on February 02, 2011 at 18:02:04:
That will happen. The rims are the same size, but the axles are different. They are sort of interchangeable, but not 100%.
