Re: What kind of pto silo blower will work on smaller tra...
Posted by farmerdoug on February 02, 2011 at 19:38:09 from (97.90.227.11):
In Reply to: What kind of pto silo blower will work on smaller tractor posted by NNY FARMER on February 01, 2011 at 14:01:27:
Dad used to blow haylage up a 72' Silo with a tired 450 gas and NH 28 blower. Not a record breaker, but got the job done. I would say you would be fine, especially if corn silage- Doug
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
