Re: Can you not pull start a tractor with t/a?
Posted by mkirsch on February 03, 2011 at 05:24:49 from (64.80.108.56):
In Reply to: Can you not pull start a tractor with t/a? posted by curt in ky on February 02, 2011 at 19:57:12:
You should be okay if the tractor quit on an incline, unless you push the clutch.
As long as the engine is spinning, there is hydraulic pressure. As long as there is hydraulic pressure, the TA stays locked. As long as the TA stays locked, the transmission will keep the engine spinning.
Even if that doesn't happen, you've got a few seconds to get the rig turned across the hill, or get it stopped and in park. Brakes and steering are supposed to work with the engine off, though not as effectively.
