The Pertronex is well worth the money....I asked the same question in the tractor pulling forum.
I put one in a C, and it improved idiling 50% you can slow it down to a chug chug chug...about 250RPM!
The real test came yesterday. after this snowstorm. the farmall c with the Pertronex unit started Immediately and easily. the super c and b with conventional points, took some work to start,
The "purists" should have no objection with this unit either. the distributor does not have to be modified in any way to install the Pertronex, and can be easily returned to stock.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
