Re: 1944 FARMALL AV RESTORE QUESTION
Posted by gene bender on February 03, 2011 at 09:51:26 from (67.55.227.196):
In Reply to: 1944 FARMALL AV RESTORE QUESTION posted by IHguy on February 02, 2011 at 22:02:38:
Just because the engine was changed does not make it rare. If you want it to be original you need to change engines for one similair. You can paint it anyway you like as its your tractor. Bottom line do you want original or a cross breed. Get the original type block then stamp the same serial# thats on the seat. Replacement blocks came blank and when installed were stamped to what the oroginal block was.
